D-10 motor support grommets
What do you-all use for motor support grommets on the D-10 turntables? They are about 1/2" high, 1/2" diameter, and have a grove near one end, with a center hole slightly less than 1/4". I working on two D-10 turntables for two 46-1203 radio-record players:
Both cabinets before stripping:
[Image: http://i269.photobucket.com/albums/jj77/...before.jpg]
[Image: http://i269.photobucket.com/albums/jj77/...blique.jpg]
[Image: http://i269.photobucket.com/albums/jj77/...dfront.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Nice job refinishing!
Eico 232 VTVM Schematic
There are currently 9746 online users. [Complete List]
» 1 Member(s) | 9745 Guest(s)
