Philco 45 Volume Control
Does anyone have a good picture of the underside of a Philco 45 chassis? I would like to see the detail of the original volume control as mine has been replaced with something newer and the speaker mounting has been modified and not very well either.
Thanks
Gregb
Looking at the parts layout drawing I can see the original control was on a standoff to clear the mounting hardware for the speaker. Does anyone have a spare volume control that would work in this radio that they would be willing to part with?
Thanks
Gregb
Do you still need the picture? I got mine in the mail but forgot about this post.
I do not need the picture anymore, Thanks
Gregb
There are currently 9097 online users. [Complete List]
» 2 Member(s) | 9095 Guest(s)
