P-1515 WA record player
I just obtained this, and the turntable does not turn. When turned on (to operate the turntable) there is a very slight movement-that is all.
Also, when the dial is then switched to off, there is a slight "thump" that can be heard through the speakers.
Otherwise, it appears to be in fair condition. Any suggestions, or comments are appreciated. I live in southeastern PA, and would be willing to pay for repairs. Thanks!
Philco 91 Tuning Condenser
There are currently 10180 online users. [Complete List]
» 2 Member(s) | 10178 Guest(s)
