Help with Cleaning Dials
My 38-5 dial plastic is pretty filthy, I assume that using some water on this to help clean off the dust and residue is safe? I'm not going to wipe off the dial markings or anything am I?
Second, the dial is discolored (darker) on part of the face, I assume this is from sun, heat, and so forth, is this reversible or is it just one of those things that happens with age and I should live with? Doesn't bother me but if there is a way to address it then I would (Short of a new dial)
John
KC0EYF
DO NOT USE WATER OR ANY CLEANER!!!
You really cannot clean them.
The inks on Philco dials is water soluable!!! You will have a FULLY cleaned dial if you do.
Great Advice Chuck. I made that mistake on my first restore. Fortunately "Radio Daze" had a replica. However I would have preferred the original....that went down my drain. Icon_cry
OK, Message recieved! Glad I asked the question.
I won't use anything to clean the dial. Thanks for the quick reply, I was getting antsy to do just that.
I knew I could count on you guys for help! Now, if I could just generate capacitors out of thin air.......and wave my hand and have them all soldered in.........*Poof*....Were you saying something??....
Thanks again.
John
PhilcoPhil Wrote:Great Advice Chuck. I made that mistake on my first restore. Fortunately "Radio Daze" had a replica. However I would have preferred the original....that went down my drain. Icon_cry
Buy one of Mark Oppat's dial scales. They replicate the original FAR more than any other. Or, several gents like Ron make their own.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
