what type of walnut is this?
I am in the process of re-veneering another 70b and I have bought figured, burl, and quarter sawn but I can not find this grain pattern. does anyone know what type of walnut this is?
Crown cut I believe
This looks closer than anything else I have bought so it will have to do.
http://www.ebay.com/itm/151228333073
Rotary-cut, good enough for the side of a cabinet. It will be toned very dark anyway, so you won't see the grain.
That isn't rotary-cut, it is flat cut. Anyway, it would look really nice on the sides of your 70.
M R Radios   C M Tubes
So is the ebay veneer the right cut? The picture in the first post is my restored 70 with original veneer, I want the veneer to be the same on the one I am starting on.
The first post picture looks lighter than it really is, it is actually a syrup color.
Yes, the original veneer on your cabinet is flat cut, sometimes referred to as plain cut, as is the veneer you bought on Ebay. A quarter-cut veneer would have a close, straight grain without flame grain and figure.
Thanks Steve
Hey guys, that is a light color Claro walnut, which is what the cabinet makers used on the radios in the 30s,.. The Stratosphere sides were done with Claro, and a lot of Midwest cabinets displayed it , as well.
The lighter the color, the harder the true Claro is to find.
I am referring to the first photo of the veneer on the cabinet.
I am too sure about the Ebay stuff. It has white specs on it, which is not natural to the species.
I used Claro walnut on the 89 cathedral I just listed on Ebay,
which is Rift, but a beautiful veneer.
Kenneth
You're right, it can't be rotary with the book matching.
Kenneth, your 89B is beautifulIcon_thumbupIcon_thumbupIcon_thumbupIcon_thumbup
Ron, I hope it is OK, I'm going to go ahead and post the link http://www.ebay.com/itm/Antique-Radio-Ph...2a37cc4e5b
Why thank you , Steve.
So far, my cabinet restoration is only worth $101.00,..
Man, if that is all I could get for my work, I would be Skinny Kenny.!
Maybe I will gain more along the way.
Otherwise I will keep it and wait until one of you guys is not too busy restore the electronics for me.
Thank you again , Steve, I appreciate the compliment.
Oooooooh shiny! Eyes hurt now Icon_lol
Kenny, What happened to the RCA Victor R-7-A Tombstone Radio
I was gonna try to get both of the resto jobbers?
Beautiful radio.
