46-480 FM Antenna Question
Can anyone tell me what the female connector on my 46-480 labeled as "FM Antenna" is for? Is my radio missing something? I have no FM reception at this time. Also, how do you set the station preset switches? In modern lingo, how do you program them? Thanks!
Your radio is missing the male plug with a pair of wires that hang out the back. That is your FM antenna. FM reception is impossible without it.
Setting the pushbuttons is easy. Move bandswitch position to P.B., press button to be set. Go behind the radio, adjust the threaded rod for the button depressed to tune in the station, adjust the trimmer (antenna) just above the threaded rod for maximum volume.
Richard
Thank you Richard. I guess the question now is how do I work around this or find an original plug with wires? The schematic shows a brown wire and a white wire coming out of the male connector and a length of 45". I'm seeing that only two wires of the plug are utilized. Is this the antenna and is it routed around the perimeter of the cabinet?
Hi and welcome!
You asked:
Quote:Is this the antenna and is it routed around the perimeter of the cabinet?
Yes, and yes. Icon_smile
Two wires may be used, or if you plan to keep your radio in one location, you may connect an FM dipole to those terminals. The wires should do fine, however.
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3255 online users. [Complete List]
» 1 Member(s) | 3254 Guest(s)
