Philco 50 (early) survivor
Threads: 92
City: Clayton, NC
Found yesterday in Winston Salem, NC.
Cabinet good shape, needs grillecloth.
Chassis virtually no rust, still has both copper mershons and ALL Philco globe tubes!!
Besides a good cleaning and grillecloth replacement, I am not sure if I want to do anything else to this survivor!!
Threads: 55
City: Evanston, IL
Threads: 92
City: Clayton, NC
Thanks, Guys! Oh yes, and it cost 100.00 !!!
Threads: 562
Well worth it Tom, and the cabinet looks good.
Chassis cleans up easy if no rust present, so I do not even consider it a chore.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 562
I know what I will do.
I will restore another 70, patch the middle hole, put the On/Of trigger switch in the back and declare it a 50.
Threads: 55
City: Lexington, KY
Threads: 11
City: Black Mountain, NC
What year by chance?
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Threads: 562
Should be 1931.
They used 70 cabinet and drilled the front panel for 50 shaft pattern.
Threads: 367
City: Dover, OH
Ah, very nice! I have a model 50 in the later cabinet style. Paid about the same for it.
Threads: 562
50 is the one with the transformer underneath the chassis, right? Or which one was it?
That was a dumb idea though.....
Threads: 43
City: Atlantic Highlands, NJ
Great condition! Good luck with it.
Threads: 92
City: Clayton, NC
Yes, power xfrmr is under the chassis.
Threads: 562
Dumb. That's just dumb. Like the transformer runs so cool that being in enclosed tight space will benefit it greatly and at the same time the rest of the under-chassis denizens.
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.
I would start from touching Test Point 12 on the sch.
See if you hear hum.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
There are currently 3924 online users. [Complete List] » 1 Member(s) | 3923 Guest(s)
