Philco 50 (early) survivor
Found yesterday in Winston Salem, NC.
Cabinet good shape, needs grillecloth.
Chassis virtually no rust, still has both copper mershons and ALL Philco globe tubes!!
Besides a good cleaning and grillecloth replacement, I am not sure if I want to do anything else to this survivor!!
Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup
Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap
Done good.
Wow.
Thanks, Guys! Oh yes, and it cost 100.00 !!!Icon_thumbup
Well worth it Tom, and the cabinet looks good.
Chassis cleans up easy if no rust present, so I do not even consider it a chore.
Outstanding find!!!! Don't see them in that shape out in the wild very often. Icon_thumbupIcon_thumbupIcon_thumbup
I know what I will do.
I will restore another 70, patch the middle hole, put the On/Of trigger switch in the back and declare it a 50. Icon_lol
Very, very nice! Icon_thumbup Icon_thumbup Icon_thumbup
What year by chance?
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Should be 1931.
They used 70 cabinet and drilled the front panel for 50 shaft pattern.
Ah, very nice! I have a model 50 in the later cabinet style. Paid about the same for it.
50 is the one with the transformer underneath the chassis, right? Or which one was it?
That was a dumb idea though.....
Great condition! Good luck with it.
Yes, power xfrmr is under the chassis.
Dumb. That's just dumb. Like the transformer runs so cool that being in enclosed tight space will benefit it greatly and at the same time the rest of the under-chassis denizens.
Philco 91 Tuning Condenser
There are currently 2448 online users. [Complete List]
» 1 Member(s) | 2447 Guest(s)
