Philco Made Garbage Cans!!!!
This will look good in the radio museum.
[attachment=3728]
A good place to put used chewing gum and beer cans - yes?
[attachment=3729]
The smaller bottle says "Edison Battery Oil". I always thought that oil in your electrolyte was bad. Guess I'll have to start lubing my batteries.
Oil in batteries was NOT in electrolyte - it was poured on TOP the electorlyte to prevent the evaporation.
That isn't a garbage can, it's the glass case for a Philco battery. But I think you know that already, and are just kidding, right? ...right? Icon_wink
Could be - - -
It does look a lot like a small kitchen trash can, doesn't it?
There are currently 10445 online users. [Complete List]
» 1 Member(s) | 10444 Guest(s)
