FM Reception 46-480
Hope all had a nice holiday weekend. I get lousy FM reception in my area. Just a couple of stations and they are somewhat fuzzy. My 46-480 picks up several stations with the antenna I made but I have to turn the volume all the way up to barely hear anything. AM stations are just fine. Can anyone shed some light on the FM? I have a modern radio that picks up the same stations but I get plenty of volume from that radio. Thanks!
Hi
Have all paper and electrolytic capacitors been replaced? Tubes checked? Set aligned? And...is the set's FM antenna connected properly?
Thanks! Yes to all of the above. Everything went smoothly. I did have a problem with the Loctal sockets after I pop-riveted them back into the chassis. The heads of the rivets wouldn't allow the tubes to seat properly. I filed the heads and cleaned all the sockets per instructions found in another post and the tubes seat well now.
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2433 online users. [Complete List]
» 3 Member(s) | 2430 Guest(s)
