Radio Daze PHILCO Decals Corrected!
BTW there is no decal for the bandswitch on the 37-116. The 37-116 was Philco's next to the top of the line for 1937. It's a very nice set and a great player once it's been serviced. Please do have someone look it over before pressing into service. As Steve said.
The originals I have had no decal on that switch which makes sense since its function is displayed on the dial. I have seen some with decals added.
Question about the RadioDaze decals. I am about to use some, are these the type you soak in water a minute or two and then slide them on the radio?
Yes they are the the water slide type.
Philco 91 Tuning Condenser
There are currently 10174 online users. [Complete List]
» 2 Member(s) | 10172 Guest(s)
