Threads: 113
City: The Villages
Hi guys,
I just did a recap on this Hippo. I even replaced most of the mica caps as well as a good amount of out of range resistors. The tubes have been tested and I replaced 2 of them. Performed an alignment.
Reception is great but between stations there is a VERY noticeable squeal. Any ideas where to look?
http://www.nostalgiaair.org/Resources/634/M0013634.htm
Thanks
Eric
The Villages, FL
Threads: 145
City: Elko,MN.
I have run into this before, and have been able to get rid of it by fine tuning the alignment.
murf
Is your loop antenna properly connected? If one wire is disconnected, the set will squeal, howl, buzz, and in general not play correctly.
Threads: 55
City: Evanston, IL
If your loop is connected you may also try a slight stagger-tune of the I.F.'s as suggested above.
Chuck
Threads: 113
City: The Villages
It came with no antenna. The loop is connected but it is from what I think was a 46-250. Would that make the difference? If so what can be done to correct this?
Eric
The Villages, FL
Threads: 562
If it squeals on you tell it it is not an honorable thing to do.
And make sure it is loop and not a noose
Now on teh seriuous note, I only have the sch for 48-620, but if it is also an AC/DC set, there is a capacitor or a capacitor in series with small inductance conencting the electrical common and RF common (chassis). If this cap or inductor are bad the radio will misbehave including squealing, howling, roaring, motorboating and occasionally uttering some bad words on its own at which point you should turn it off, pull the belt from your pants, give it a good threshing and then inspect for bad parts and re-align.
Threads: 113
City: The Villages
OK Morzh, here is the schematic for the 48-460
48-460
Would it be C5?
Eric
The Villages, FL
Threads: 113
City: The Villages
Something else that I just discovered: With the antenna disconnected I get a soft high pitched squeal that changes with volume but doesn't change with movement of the tuning cap.
Eric
The Villages, FL
Threads: 562
No. C19.
But C5 is also worth checking as without it the antenna will simply not work.
Threads: 113
City: The Villages
C5 is new. Any idea why there is a soft squeal with no antenna connected?
Eric
The Villages, FL
Threads: 562
Is C19 new or is it even there?
Threads: 113
City: The Villages
Yes it is there. I have 2 schematics. This one shows a .2mf and the other shows a .5mf. I used a .5 because that is what was in there. It didn't have the wire wrapped around it. I don't think that is needed anymore. Is it?
Eric
The Villages, FL
Threads: 562
Did it have a wire wrapped around it before?
0.2uF or 0.5uF does not matter, it is an RF link cap between the two commons, either will work fine.
Threads: 113
City: The Villages
No wire, so I tried one. No change.
Eric
The Villages, FL
City: Kentucky
Hippos usually have rubber wiring. Did you replace any wires, or cover them with heat shrink? If so, check the routing of the wires. Sometimes solving a squeal is as simple as moving a wire 1/4 inch. If this isn't the trouble, i think your alignment might be a little too "hot". Like Chuck said, un-align it a little and see if the squeal stops.
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9084 online users. [Complete List] » 3 Member(s) | 9081 Guest(s)
