Philco Phinds
Phinally phound a 90 Cathedral at auction on Saturday.
Also phound a tabletop at antique shopIcon_biggrin
Phantastique!
Nice, your 90 still has the copper Mershon capacitors that look beautiful when polished up a bit.
...and you can try to reform the Mershons.
Icon_lol just kidding.
Both those radios look great, especially that Philco table model. Usually those are well beaten on when I find them around here.
Great Phinds! ... Lucky!
Thanks guys. I had a flipper bidding against me for the 90 but I wasn't backing-down!
very nice......Good luck with them. You found a good bunch!
Way to go, Tim!! Icon_thumbup
Those Philco phinds look phantically phine! Icon_smile
The contrast between the wood finish, the cream paint, and the grille cloth on the table model is sharp.
Philco 91 Tuning Condenser
There are currently 10176 online users. [Complete List]
» 2 Member(s) | 10174 Guest(s)
