Philco 40-150
There is a 40-150 available in the need of push buttons replacement.I would like to work on it, as these tuning buttons design present some challenge to me.(I will forget for a moment about my quest for the 10 best). Are those buttons ever available or in the worst case can be fabricated? Thanks.
Renovated Radios has repro push buttons. I just got some for my 39-25 project. http://www.renovatedradios.com/parts.html
There are currently 8885 online users. [Complete List]
» 1 Member(s) | 8884 Guest(s)
