My First 90
I have completely recapped and repaired as needed my first Philco 90. Here are a few pictures.
Gregb
very nice job greg Icon_clapIcon_clapIcon_clap
What a nice job on a great radio. Love those caps, nice job on them.
Jerry
Thanks, it plays really good, very sensitive and sounds good as well. Middle of the day with my 20' basement antenna I was getting Calgary stations that are 300 miles south of me. OH, and full set of globe tubes as well.
Gregb
gregb, I forgot to comment on those. Sooooo nice.
Jerry
she's a beauty Greg. Great work!
Great looking radio and the mershons are shined up Icon_smile
Excellent work, Greg! Really looks sharp. Congratulations! Icon_thumbupIcon_clap
Icon_thumbupIcon_thumbupIcon_waveIcon_clap
Excellent example!!!!
Well Done !!!
Wonderful, such a nice set!
Thanks everyone for the great comments!!
Gregb
There are currently 9640 online users. [Complete List]
» 1 Member(s) | 9639 Guest(s)
