Just bought 2 90's a 70, an 89 and 2 19's
I had a guy email me and said he had a bunch of radios. It was amazing and he only wanted .............
Let's say Benjamin was lonely Icon_mrgreenIcon_mrgreen
April Fool?
Kirk
you forgot to add "for $1.50 plus tax" Icon_smile
OH geeze,
I forgot to put april fools on the bottom, I am so stoopit.
I was half awake when I wrote this and on my way to the dentist.
Sorry guys, I am not that lucky
It said so when you posted it Icon_razz April fools round two?
YOu are right! Not April fools round 2 but I didnt forget to add it. I edited it while waiting for the dentist. It said Happy april first but i deleted it and never wrote april fools. God my memory is getting ridiculous!
Dude, you've got a bad case of the radio bug. Here's hoping you don't get better anytime soon;)
If anyone wants to know what happened to the unrelated comments in this thread regarding Dynakits, etc., they were moved here:
http://www.philcoradio.com/phorum/showth...p?tid=9223
There are currently 9652 online users. [Complete List]
» 1 Member(s) | 9651 Guest(s)
