Will this transformer work in my 38-7?
32-7833N is the Philco part number. Someone on the ARF has one that I'll buy from him if it will work.
TIA
Hi Brenda, you've probably seen this, but here are the specs for that transformer:
http://www.antiqueradios.com/forums/view...hp?t=32876
It looks very close, I can't find the exact B voltage of the 38-7.
Here's another interesting page: http://www.oldradioparts.com/2a23efl.txt
4593-004 POWER PHILCO 32-7833 320-0-320V @85ma, 5V 2A, 6.3V 2.5A, MODEL 38-7/8/9
Looks close enough to me.
I'm not really seeing what you are referring to there.
I apologize, somehow I misread the first link.
At any rate, the second link I posted shows part number 32-7833 as correct for the 38-7.
Yes, thank you. Icon_smile
Just in case my other offer falls through, will this one work?
32 8137n
There are currently 3782 online users. [Complete List]
» 2 Member(s) | 3780 Guest(s)
