New 40-155, 37-620 & 40-120 Philcos
Today I found 3 Philcos that I really liked. One is missing the front photofinish but since that guy makes them now I bought it. I have been wanting a 40-120 for a while and the third was just a pick up.
I also got a really cool Fairbanks Morse with a great dial.
Here they are:
Nice scoreIcon_clap Congrats! I have a Fairbanks Morse floor model with that same dial. it is very pretty when lit up in a dark room. The radio itself is a great performer as well, good luck with all of them.
Kevin
Philco 91 Tuning Condenser
