Philco 53A floor model
Hello everyone, I am new here and new to restoring antique radios. I am having some difficulty finding the schematics on a Philco I recently picked up in Ontario. I presume it's Canadian but cannot find the schematics on this Philco site or Nostalgiair. Is there anyone who knows this model and has a schematic or could point me to a site that may have it.
Charles
It looks like the 53AX is a console from the 1942 season, which has no USA equivalent.
Have you tried Just Radios?
http://www.justradios.com/schematics.html
Take Ron's advice, Dave at Just radios should be able to help you out.
Gregb
Thanks guys, I think I might have found it here at radio codegods . This is a 53 model not a 53A but the tube chassis layout is exactly the same. I have not looked at the actual electronics under the chassis yet though. Perhaps its electrically the same
here it is http://radio.codegods.net/node/7036
The speaker table error?
Philco 70 antenna lead
