Threads: 24
City: Edmonton AB CA
Picked this sweety up today. Looks nice but doesn't work, will put it on the list of radios to rebuild. It is a model 16RX
Main unit
Speaker Unit
Gregb
Threads: 562
Threads: 310
City: Kings Park NY
Funky little sucker, I like it.
AC: 4 DC: 1
Threads: 33
City: Horsham, PA
Surround sound, 1930s style (40s?). Nice set!
Threads: 92
City: Clayton, NC
Threads: 24
Thanks guys, I was pretty happy to find it. As the pictures show its in really good condition cabinet wise.
Gregb
You did very well, sir. Usually, you can find the chairside unit but not the speaker...and the speakers seem to be very few and far between. In other words, very hard to find.
I had a 19TX control unit for about 20 years before finally finding the correct matching speaker cabinet.
Threads: 24
Thanks Ron, I appreciate your thumbs up.
Gregb
I should clarify...when I said it took me about 20 years to find a matching speaker for my 19TX control unit, I was not exaggerating as I sometimes do for humorous effect. It was, literally, a 20 year wait!
That's how hard it can be to find those Philco speaker cabinets.
I wouldn't be surprised if several were "repurposed" into early hi-fi/stereo speaker cabinets, and then tossed when the novelty wore off. The same thing is going to happen to the radios that are being destroyed in order to be made into touch screen iPod-thingies. Once the novelty wears off (and computer standards change), these, too, will end up getting tossed to the trash heap.
So, anyway, Greg...you were very lucky indeed to find the matching pair.
Threads: 24
In the 30 years I have been in the hobby this is the first one I have ever seen in person. I have only seen pictures in books and on line. This is an American made set so I would assume someone brought it into Canada.
Gregb
Threads: 367
City: Dover, OH
Great find!
Threads: 55
City: Lexington, KY
Ditto on the great find! Did you find that locally?
Threads: 24
Yes I did, 5 minutes from home. I advertise all the time for repair work and get calls asking if I buy radios and most turn out to be nothing of interest but not this time.
Gregb
(This post was last modified: 04-14-2014, 11:56 PM by gregb.)
Threads: 97
City: Poughkeepsie, N.Y.
Greg very very nice find indeed! It looks the set was barely even used. They took very good care of it.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
