philco 41-250
howdy! just finishing this up,schematic has ant. term number 1 connected to output tranny.why?external input?
thanks,phil
http://www.nostalgiaair.org/PagesByModel...013407.pdf
Used as alignment test point. I have never used it. I use the AVC line.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
hi terry,thanks,i was thinking along those lines also,would be the same as across the speaker,phil
There are currently 7364 online users. [Complete List]
» 1 Member(s) | 7363 Guest(s)
