Hit the Jackpot Today !! 38-690 !
Threads: 17
City: Nanuet, NY
Threads: 562
Where was it listed or you heard of it privately?
Great find (hate you already)
City: Sedona, AZ/Placentia/CA
Now that is a score Rock.
Does the chassis look as good as the cabinet?
Jerry
(This post was last modified: 04-24-2014, 05:06 PM by
jerryhawthorne .)
Threads: 24
City: Edmonton AB CA
MAN am I jealous!!! Great find!
Gregb
Threads: 97
City: Poughkeepsie, N.Y.
ROCK WHERE DID YOU FIND THIS CONSOLE!! A great find....and I am besides myself! was it a local find? WOW!!!!
Threads: 17
City: Nanuet, NY
Here are the chassis pics
Rock
Image(s)
Threads: 16
City: Kokomo, IN
not only nice on outside but on the inside to!
Threads: 24
Looks like you got yourself a real fine set there!
Gregb
Threads: 1
City: Minneapolis, MN
The set was designed when some stations had hi fi modulators and broadband modulation was permitted for WLW at least. You'll need to build a small xmitter to show-off the radio. Or, at least, get a phonograph with a magnetic pickup and a preamp to connect to it.
Threads: 1
PS AM stations now not only cut the audio above 5 kHz, as required by law, they cut the low freqs too and boost the apparent loudness of their blabber-mouths.
City: Kentucky
Very nice!!! .. That's my dream radio. If I ever find one, I will probably spend a year of my life making it perfect.
John (Rock),
You did it! The mack daddy of all Philcos! Congratulations!
(p.s. I merged your two 38-690 threads into this one since it is on the same subject.)
Threads: 92
City: Clayton, NC
Bleeping Bleep !!!!!!!!!
John, you are unbelievable!!!!! An outstanding find!!!
Reckon you can find Pam Anderson for me.
Threads: 27
City: Rochester, NY
Tom, I had a good come-back for that last part but...
Don't wanna get into trouble
Threads: 310
City: Kings Park NY
We don't take kindly to poachers on this here Long Island
Arent there enough radios up where you live or did you already buy them all?
I may have to add that to my wants list. It is quite nice.
AC: 4 DC: 1
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM
Philco 91 Tuning Condenser
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM
Transistors are easy.
Or touch your fin...morzh — 04:25 PM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM
