650 Schematic
I downloaded the one from nostalgiaair.org but it is not usable.
I was going to buy the Philco manual from vintagemanuals.com but they do not have it. I also tried theoldradiofixerupperguy.com but the download for a 650 is not for a 650. Does anyone have a readable schematic and parts list?
I'm thinking of ordering from philcorepairbench.com but it looks like I would need to mail a check as he does not take paypal or CC's. I would like to work on this radio ASAP.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
I have ordered recently from the Philco Repair Bench and can safely say you have nothing to fear. It's well worth the minimal price.
Bill, I have a clean DjVU schematic if that will help. No parts list other than what you've downloaded already. I have several of Chucks schematics for various models. No better service for super clean copies, and all the tech notes TSBs, etc. etc. that come with a particular model. Not tooting someones horn for the sake of it, they really are nice.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
There are currently 9676 online users. [Complete List]
» 1 Member(s) | 9675 Guest(s)
