48-1256 radio / phono
I replaced the cartridge in the photo and the sound is clear but I can't get the (volume) sound high enough. The radio volume control works ok.Is there some way to increase volume other than turning knob?
If the shielded cable is not grounded would that make a difference ?
have someone move this to electrical forum and they will be able to help. I am useless with this topic. Icon_silent
Thanks
Lumberman, if the radio volume is fine (loud enough) and the phono is weak, it suggests that perhaps your replacement cartridge is either weak or perhaps of the wrong type. Cartridges have a wide range of output voltages depending upon construction. Selecting the proper voltage output is fairly important.
Can you advise what cartridge you installed?
Refer to the schematic as to where the shield should be tied. That may or may not be a problem. It appears the shield is grounded to the changer base.
http://www.nostalgiaair.org/PagesByModel...013612.pdf
Jerry
There are several types of cartridges some have much higher output than others. I would suspect that you have a cartridge that has a low output or is a low impedance output. What cartridge are you using??
Jerry and Terry, thank you for your replies. The cartridge I installed is a Astatic 32 it states on the box that it replaces Astatic 34;l-24-a;l-36-a;l-82-v;l-92-a. If this is the wrong type where do you suggest I look for the right one,can you test the cartridge for voltage out put. The cartridge I replaced is a Shure crystal pickup cartridge P907, below that it states 35-2643. Tim
According to the schematic the shield is grounded to the turntable chassis and not at the radio end.
Jerry
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM
Gloritone 27 Radio
Hello John, Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
There are currently 2378 online users. [Complete List]
» 3 Member(s) | 2375 Guest(s)
