1209 phono help
oops hope this better are a D-10 and a D-10A record players interchangeable in a philco 46-1209 david
David
please re-read your post and correct it. As it stands it is very confusing.
corrected i hope sorry david
D R Ford, as far as I know they both use the same power connection and the same audio connection, trough the same transformer. I might be wrong, but as far as interchangeable go, you could connect an MP3 player or a cellphone to the phono input of your radio and it would work. The D-10 and D-10A have the same footprint (AFAIK) and their only difference would rely in the reproducer.
I personally gave up on the one from my 47-1230 and sent it to another phorum member for his. But I am in the younger bunch who never really used 78 rpm records so I do not think I count.
-Mars
Philco 91 Tuning Condenser
There are currently 10064 online users. [Complete List]
» 1 Member(s) | 10063 Guest(s)
