Threads: 42
City: Ironton Ohio
Got these philcos fri and today, along with a bunch of tubes and a portable victrola.
I know the picture is crappy but I am still trying to figure out this Iphone.
(This post was last modified: 04-26-2014, 11:31 AM by tab10672.)
Threads: 562
OK, I see something close to 39-7 (with buttons) and 38-15 in plascon cabinet (uness it is painted) which is pretty rare.
Threads: 42
City: Ironton Ohio
59
Pt44
39-7
38-14
610
620
42pt-95
Dont know what model the green one is, its missing half the label.
Threads: 310
City: Kings Park NY
Harrumph!
AC: 4 DC: 1
Threads: 92
City: Clayton, NC
Good job!!!
Always preferred the 1936 bullet.
Threads: 17
City: Nanuet, NY
Wow you have some nice finds there !!! Congrats !
Rock
Threads: 367
City: Dover, OH
This must be the weekend for good finds! Great haul! ![Icon_thumbup Icon_thumbup](https://philcoradio.com/phorum/images/smilies/icon_thumbup.gif) I used to have the yellow version of your little green Philco, but can't recall the model number. It's postwar, but that's all I can remember about it.
City: Kentucky
Very, very nice haul! ... You done well.
The green one is a 53-561. The B572 is nearly identical, but the dial scale is just slightly different (no "Special Services" band on the B572).
Threads: 92
City: Clayton, NC
38-14 is pretty good set! I have a CS and a table set.
Threads: 562
38-14 is for all intents and purposes a AC/DC version of 38-15.
The dial goes from 2 to 6 MHz vs 6 to 18 on 38-15, but the sch is very much the same, chassis the same, box and even grill in some versions....
Threads: 268
Very nice haul my friend!!!
I'm sure you'll have a great time
fixing them up!!
Threads: 42
City: Ironton Ohio
I thought I had the brass tab bezel for the 39-7 but mine incases the buttons. So I need to find that, the rest look to be complete. I payed the most for the 38-14 because it has been completly restored and done right, not just the filters. There was also a beautifull mod 44B but by the time it came in I had spent my budget.
Todd
Threads: 42
City: Ironton Ohio
Morzh, the 38-14 scale reads 2.3 to 8.0
Threads: 562
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9637 online users. [Complete List] » 2 Member(s) | 9635 Guest(s)
