New 44b
Just picked it up.
Very nice! Those are real good players too. They sound excellent.
That is a nice radio.Icon_thumbup I had one once, wish I hadn't sold it.
M R Radios   C M Tubes
Steve,
cant you just make another, lol
Actually, I have though about it. If I could find a ratty flat front 44B, I would make a cabinet with the insert front panel like yours.
I have a flat front with a rough cabinet that I always wanted to restore but the veneer may be to far gone and not worth the effort.
Hey, I know a guy that likes ratty cabinets Icon_mrgreen
Very nice find
If your ever going away and need a baby sitter for this radio just let me know. I'm there for you!
Gregb
Very nice! Icon_smile
Philco 91 Tuning Condenser
There are currently 10386 online users. [Complete List]
» 2 Member(s) | 10384 Guest(s)
