46-480 Chassis Layout
I need a copy of the chassis layout for this radio. I can't read the designations for the alignment adjustments (C2? thru C3? etc.). Know where I can get one? Thanks!!!
http://www.nostalgiaair.org/PagesByModel...013634.pdf
Icon_sad Thanks but you found a 48-460. My radio is a 46-480 and the NA copy of that is to dark to positively ID the individual numbers. I'm hoping for a different source that has a clearer page.
Hi Owells
Have you considered purchasing the service info from Chuck?
His service information packets have earned rave reviews for their clarity and completeness. Full details here:
Philco Schematic Information
I ordered the service info for my 630B and 650X from Chuck just a few days ago. Can't wait to get them! Brian has ordered from Chuck and told me they are of the best quality and that's good enough for me.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Well I did order it just now thank you. Icon_smile I'm looking forward to receiving it.
There are currently 3574 online users. [Complete List]
» 2 Member(s) | 3572 Guest(s)
