111 grillcloth cardboard frame.
Threads: 562
Jamie
If I knew where to buy them tongue depressors...Where is MASH 4077 when you need it.
Well, will drop by Michaels tomorrow, see what is there.
Threads: 26
City: Hayward, California
or maybe popsicle sticks...at your grocery store.
Threads: 337
City: lawrenceville nj
hey morzh
theirs a new hobby lobby here in Lawrenceville
sam
Threads: 562
Sam
Like Michaels or more towards technical side?
Mike.
City: Kentucky
Hobby Lobby is sort of like a super Michaels. It's a lot better, but not really oriented to electronics. You can get popsicle sticks at the grocery store.
(This post was last modified: 05-13-2014, 07:08 PM by Jamie.)
Threads: 562
Well, Michaels is 2 miles away....
Threads: 48
City: Tioga, Texas, USA
If the board material is too far gone, you might want to look at some MDF panel material at Lowe's or Home Depot or your local lumberyard. I had to use some MDF material to replace a crumbling grill cloth backing board on my 40-201. It worked well and was about the same thickness and the original material.
Joe
Threads: 562
I went to Michaels, bought a matting frame...looked at it awhile....today brought it back and returned it. I need some masonite/mdf for it. Cardbord won't do well in there.
Threads: 310
City: Kings Park NY
I could have mailed you a piece of original backer board by now. I can just give it to you when we get together.
AC: 4 DC: 1
Threads: 562
OK, thanks Kirk. It can wait.
Threads: 112
City: Medford OR (OR what?)
There is a card-like material, about a 1/8 of an inch thick used to protect stacks of Masonite and other materials in transport. It is very much like the material inside of old car door panels. Many hardware dealers save it. I purchase sheets of 4' X 8' for around $3.
Threads: 562
To be perfectly honest, the more I look at the panel the more I wonder if these 4 beams have any role in keeping the cloth taut at all.
I mean, they are 1/2" wide flexible beams whereas the panel itself is over 1" wide on each side, which makes it the main stretching force for the cloth. if anything they are flexible and somehow I think they suffered their fate exactly for that. Those that are not broken off are still cracked at where they meet the circumference of the frame.
I wonder if I should even bother.
City: Sedona, AZ/Placentia/CA
Mike, if the grill cloth was not glued to them or even if it was, I suspect that those are there to keep the grill cloth from jumping back and forth with the speaker putting out some strong sound.
Jerry
Threads: 562
It was not glued to them or there'd be some glue residue on both the cloth and the strips, and possible damage.
yes I suspect it is there to keep the cloth to be sucked in (maybe) during a strong pull because a strong push they cannot keep it from unless it was glued to them (which it wasn't).
Threads: 26
I would say the main reason they are there would be just to help keep the shape of the cloth. Without it, the cloth would stretch easier and wouldn't be as taught after some time. Just a little bit of backing to keep its shape longer. Surprising what just a little will do to help keep its shape. Is it probably broken some from being bumped again and again over the years.
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 8309 online users. [Complete List] » 1 Member(s) | 8308 Guest(s)
