15 (X) tubes
The June of 1932 15 uses 44s and 37s. I don't think I have ever seen a 37 as a globe tube, maybe the 44 and certainly the 42s in the PP output.
Do you think there was much likelihood of this radio have some/any globe tubes?
Almost all of the tubes in it are STs with printed logos. So they are nice, but wrong for a restored unit.
Man, this thing has some big iron.
When introduced in June 1932, the radio definitely would have had a full complement of the globe style tubes. 1933 was the time of changeover to the ST style, and tube production gradually switched over fully to ST as the year progressed.
I have a few globe 44's with 1933 date codes, so they were still being made that way into the early months of 1933. I have seen globe 37's but they are quite scarce. Its possible that in late production of the 15X there might have been a mix of globe and ST style tubes installed.
I have a few globe 37 tubes. As Mondial said, they seem to be quite scarce.
Russ, there's a 37 globe tube on ebay
The 15X I got from Willie had a couple of globe 37's and 44's, I replaced the rest of the ST's with globes. Looks Great and plays great, one of my new favorite radios.
Gregb
I think that I will look around a little before I spend $45 each on the 37s.
From an estate with about 10 other radios:
The top has been refinished already, so I will probably restore the whole cabinet. Anybody need a piece of carpet?
The set originally had all globe tubes. The 37s are out there. The 42 globes will be the most expensive.
I am in the middle of restoring a model 15X chassis/cabinet. It is definitely NOT the easiest cabinet that I have ever done......
I think that $45 each is excessive for a balloon type #37, since it is not a power output tube and not really a high demand tube. If it's one of the ones under the tube shield why even worry about it?
They are out there for much less than 45.00.
In fact, I don't believe that I have ever paid more than 10.00 for an NOS one.
45.00 is more like you would pay for a globe 42.
The ones I got cost $10 each, nice finishing touch to a nice radio.
Gregb
Well, if you find any more Philco brand ones for $10, let me know.
I will but they are few and far between.
Gregb
It took a long time (~4 years!), but I finally found a few to complete my 15DX. I paid around $45 BIN + shipping for the three untested. I got lucky and thy all test like new Icon_smile
Philco branded globe 80s and 42s are pretty scarce too. I suggest you set up a search with email alerts for "Philco globe" on ebay and be patient. Also ask around on the forums and radio clubs.
[Image: https://farm3.staticflickr.com/2924/1360...ea53f7.jpg] [Image: https://farm8.staticflickr.com/7099/7270...67b21f.jpg] [Image: https://farm8.staticflickr.com/7084/7161...82edfb.jpg]
Philco 91 Tuning Condenser
There are currently 5869 online users. [Complete List]
» 1 Member(s) | 5868 Guest(s)
