05-21-2014, 10:01 PM
Kirk, I think you are on the right track. A couple of coats of sanding sealer followed by the toner should do it.
M R Radios C M Tubes
Mikes 70 DONE
Steve M R Radios C M Tubes
05-22-2014, 07:13 AM
Thanks Steve,
I went to buy it and boy has it gotten expensive. I took 4 years to use the last can so I think I will get my moneys worth. ![]() Kirk Times I have been electrocuted in 2021
AC: 4 DC: 1
05-22-2014, 09:28 AM
Today I unclamped the base and it is nice and strong. If I dropped it off the 2nd floor it would survive. well, the base would...
I glued and clamped all the separations from the arch and the sides and tomorrow I will sand to remove any excess glue and grain fill the arch and molding on the front. Times I have been electrocuted in 2021
AC: 4 DC: 1
05-23-2014, 04:19 PM
Kirk,
That is quite a job you are doing. I expect you will start getting inquiries regarding rrefinishing other radios. Thanks for sharing, Henry
05-24-2014, 07:09 PM
Unclamped the cabinet for the final time. I was going to grain fill but I found a veneer issue I didn't want to leave.
AC: 4 DC: 1
05-25-2014, 01:20 PM
GRAIN filler!!
Grain filler was finally applied to the cabinet! I stripped the molding and put sanding sealer on it. Will tone tomorrow. All veneer is fixed, the entire cabinet is glued and solid. Faca and grill are completed. Times I have been electrocuted in 2021
AC: 4 DC: 1
05-26-2014, 12:59 PM
Toning day,
Taped off the columns and toned the inside grooves Ex Dk Walnut. Then toned the entire cabinet with a medium walnut. I want to let the lacquer set for a day so I can sand the cabinet before clear. Too much dander in the air and the finish is not smooth. Times I have been electrocuted in 2021
AC: 4 DC: 1
05-26-2014, 06:08 PM
Take your time Kirk, no rush
05-31-2014, 06:01 PM
Today was rebuilding day. I took the freshly toned molding and attached it back on to the cabinet with the original nails and added some glue. I filled any crevices and the countersunk nail holes and tomorrow I will finish toning the trim, Put the face back in and clear clear clear...
In about a week I will finish sand and wax her up. Times I have been electrocuted in 2021
AC: 4 DC: 1
06-03-2014, 08:03 AM
Can I say...........JUST BEAUTIFUL!!
06-03-2014, 09:33 AM
Bad start to a day!
Finished toning and Untaped to reveal pulled up finish and perfect brown seeped under the tape. Have to strip and re-start. Times I have been electrocuted in 2021
AC: 4 DC: 1
06-03-2014, 09:48 AM
Bad Perfect Brown! Bad!
06-04-2014, 03:33 PM
Ok I finally got it right.
![]() I toned the front and then cleared 6 good coats. Sanded 400-2000 and will wait a day or so for the cabinet finish to harden. Then I will Apply some pumice and rub out the cabinet. Since it is a high gloss finish I will rub it out again with lemon oil and then wax her. Times I have been electrocuted in 2021
AC: 4 DC: 1
06-04-2014, 03:46 PM
And you people were serious when you told me that I could do all this!
I would probably retire by the time I finished it.
06-05-2014, 03:12 PM
Well I buffed her out with oil and cloth and then added 6 coats of wax.
I re-assembled her and now to let the wax harden for a week or so. Times I have been electrocuted in 2021
AC: 4 DC: 1
« Next Oldest | Next Newest »
Users browsing this thread: 14 Guest(s) |
