My Grandfather's Radio
SUPPER nice console!! Looks good and I bet it plays good to!
this is interesting, this radio I bought a few weeks ago, came from Spokane, Wa. FdSpokane is from Spokane, Wa. The guy I bought the radio from, said it was his Grandfather's. It didn't work when I bought it. Has to be the same radio. That's interesting.
Michael
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
Could be!
Funny world...
Icon_smile
I sold mine since the picture was posted, probably about 4 years ago. It was replaced in the kitchen by a model 15.
