Atwater Kent 84
Started working today on the set.Great workmanship, weird coils and strange resistors. Does anyone know how to read the value of those? Tried to compare the known values of certain resistors with their markings - makes no sense at all. Nostalgia Air has limited info and alignment procedure is missing.Hope after recapping it will come to life.
Check out the resistor info here:
http://www.atwaterkent.info/TechData/akR...rCode.html
and additional info here:
http://www.atwaterkent.info/TechData/akS...Index.html
Carl
Northern Panhandle, WV
There are currently 6090 online users. [Complete List]
» 1 Member(s) | 6089 Guest(s)
