new safety caps from Justradios
Yes pretty much it, it is a some sort of breakown voltage.
BTW Mouser carries Lelon and Xicon, the latter has been aound forever.
But they are mostly GP ones.
Did I say Xicon, I was thinking of Xunda brand caps, Xicon makes cheap parts, and it shows in the gauge of wire leads they use, but I don't think that they are inherently bad or fraudulently rated. Xunda caps are garbage, they are the reason the Toshiba DVD player will not power up anymore. Lelon is a notorious crap capacitor brand, a Taiwan brand yet, I have a computer tower with several swollen Lelon caps on the motherboard, why Mouser pedals their trash I do not know. Su'scon is one I have seen fail in LCD monitors quite frequently. Then you have ones with a name that is sort of like a good name brand, but misspelled like Robycon
If you want to know which electrolytics to stay away from, try www.badcaps.net , whenever I find a mystery brand I run a search on that site. You can also try mystery brands of polyester film caps, I did with the TC brand ones some places sell, it seems there is nothing noteworthy about them, at least in a negative way.
Just checked my last order of caps from Mouser from about 2 months ago they were all high ripple. Blind pigs finds a acorn. Thanks again David
Thanks for the link to the ceramic safety caps. I keep screwing up and getting the plastic box type with very short leads Icon_sad
They don't seem to carry much in the way of 500v caps at Mouser but Digikey has a nice selection. 10uF @ 500v, 10000 Hrs @ 105°C Nichicon are $1.83: http://www.digikey.com/product-detail/en...ND/3664442 Only $1.44 qty 10+.
That being said, JustRadios has great prices on mica caps and some hard to find stuff like 1W and 2W resistors in the megaOhm range and higher voltage (1000V+) caps.
Thanks for the link, Bob... I need to get to digikey more often. they were the only place that carried the caps I needed for the PS in a battery set who didn't want 35 bucks a piece for them.
I've also ordered some of the ceramic caps from mouser.. along with the caps that were backordered (Space restrictions limits my flexibility)
There are currently 10546 online users. [Complete List]
» 2 Member(s) | 10544 Guest(s)
