46-1209 tone issues
I have done a re-cap on my 46-1209. It was playing fine for a while now the tone seems to change on its own. Even if I turn the tone knob some times it don't Chang the sound. Any suggestions ?
Thank you
Bad solder.
Bad tone potentiometer.
How do I check if the solider is bad ?
You could take an insulating stick and poke at the wires around the tone control and see if you see any changes.
I would start from checking the pot itself first.
Ok I'll start there thank you
A dirty or worn tone pot will cause this.
There are currently 10221 online users. [Complete List]
» 2 Member(s) | 10219 Guest(s)
