Philco 90 - I finally found one!
Hi all,
I have been looking for decent Philco 90 cathedral for some time. I managed to snag this one the other day.
[Image: http://i135.photobucket.com/albums/q136/...ftSide.jpg]
[Image: http://i135.photobucket.com/albums/q136/...RtSide.jpg]
[Image: http://i135.photobucket.com/albums/q136/...A1Back.jpg]
It even has a half way decent original finish. I purchased it from the family of the original owner. It had the original Philco operating manual stashed in the back of the cabinet. It was a nice find! Icon_biggrin
BTW, I do have the original speaker. It was removed for shipment and I haven't reinstalled it yet.
Oh, If anyone happens to have an old copper Meshon cap around, please let me know. I would like to purchase it. I would like to restuff it and replace the non-original can in this radio.
Ed
Hi Ed
Great find! Congrats!
Goodo on you, etech. I've had lousy luck finding anything from radios to variacs the past month. My luck's GOTTA change. Can't get no worse. Icon_sad
There are currently 9689 online users. [Complete List]
» 1 Member(s) | 9688 Guest(s)
