Harvey-Wells TBS-50C Bandmaster
That's one of the cleanest ones I've seen! Also looks like it's been used lately it has a new cap for the carbon mike bias.
Hi Larry
So how are you and the H-W getting along?? Have you had a chance to get a power supply put together?
Sad to say I have it listed on QRZ for sale. After much hemming and hawing I made the difficult decision to focus on a solid state transmitter with digital display I have and let the H-W go. The fact that I have accumulated just too many units also factored into the decision. After going through everything to get the H-W I feel bad about letting it go but choices had to be made.
Larry
There are currently 6067 online users. [Complete List]
» 1 Member(s) | 6066 Guest(s)
