Philco 49-506 refinish
Started on a Philco 49-506 awhile back.  Here's a summary of the progress on refinishing it.
AS RECEIVED:
[Image: https://www.dropbox.com/s/1o5mkjkjlgh0bd....jpg?raw=1]
TOP AS RECEIVED:
[Image: https://www.dropbox.com/s/7rbncxjzwzl1x5....jpg?raw=1]
DISTRESSED SIDE FINISH:
[Image: https://www.dropbox.com/s/svxo35n7eklq1m....jpg?raw=1]
CLEANED UP:
[Image: https://www.dropbox.com/s/e716pyjbz3r12n....jpg?raw=1]
STRIPPED:
[Image: https://www.dropbox.com/s/syb8ibrwkwhq2n....jpg?raw=1]
TONED THE BASE, SANDED, LACQUERED, SANDED, LACQUERED, RUBBED OUT:
[Image: https://www.dropbox.com/s/rq834pcfkp6zu8....jpg?raw=1]
TOP:
[Image: https://www.dropbox.com/s/2u4hot5zrpwjue....jpg?raw=1]
Flying Wedge is a sharp looking radio for sure, and the fact that you did not alter it adds to the value.
I like it. At some point I will get me one.
Not a big fan of these radios but I kinda like it restored.
I may have to rethink and own one. It will kill 2 birds with one stone.
I get the radio and mike gets to own the chassis for a while Icon_lolIcon_lolIcon_lolIcon_lol
Oh and great job!
I hate restoring Transitone chassis. I do not like restoring hot chassis or floating ones in general.
But I like the looks of certain AA5 and such radios, so I compromise.
There are currently 9420 online users. [Complete List]
» 1 Member(s) | 9419 Guest(s)
