Threads: 64
City: Northbrook, IL
On one of my Philco sets the sectional wire-wound resistor (called B.C.resistor or voltage divider) even though having correct resistance between the sections is missing some insulation. Would like to have it replaced. In general, is it possible to sub the defective section or the entire unit with a non wound resistors, observing correct wattage, of course. If so, how to calculate that wattage?
Thanks.
Threads: 563
Wattage is always U-square over R.
You know the voltages at the taps of each section and each section's resstance, so the difference of the voltage between any two pins (or the same measured directly as voltage between pins) squared over its resistance will be your disipation, then use a factor of at least two.
Threads: 14
City: Irvington, NY
If the resistor has the correct resistance and is fully operational, why replace it?
If it is the type I am thinking of, it is insulated with a winding layer of varnished thread. You can easily re-insulate by rewinding it with linen lacing cord it if it concerns you.
Threads: 64
Mondial,
It looks like it has been overheated at one point or another and I can see the exposed naked wire. By re-insulating you mean running the lacing cord between the wire turns?
(This post was last modified: 07-11-2014, 10:22 PM by fields 100.)
Threads: 26
City: Hayward, California
How about liquid tape. Would that work?
(This post was last modified: 07-11-2014, 10:51 PM by Warren.)
Threads: 64
Not sure, it has to get between the turns. I will have to, while rewinding, maintain constant gap between them. Besides, there is a temperature issue.
Threads: 563
I am not sure liquid tape is made to withstand heat.
On the other hand if the resistor exhibits correct reisitance, I would not as much as lift a finger.
Threads: 14
City: Irvington, NY
I would just wind a layer of cord on top of the resisistance wire, as was done originally. Under normal operation the resistor should never get hot enough to char the cord. In any case the previous overheating should have had no ill effect on the resistance wire itself
Threads: 64
Morzh,
I am aware of the formula, my concern was the cushion factor.You think two is good enough, even in case of some possible short? I am not sure what happened with it in the past, perhaps something nasty,as the insulation went off on one section and the wire looks discolored , overheated.
(This post was last modified: 07-11-2014, 11:06 PM by fields 100.)
Threads: 64
If I just put layer of cord on the top, how will it prevent naked wire turns from touching each other and creating partial shorts, now or in the future?
Threads: 14
City: Irvington, NY
It never had any insulation between the turns, just the spacing between the turns. The wire should have been wound tight enough so the turns will not shift. The thread covering was just for protection.
Its just like a wirewound pot, the wire is not insulated, and each turn is isolated from the next by the spacing.
Threads: 563
Fields
When I said "at least two", I meant exactly that, at least.
For small resistors I use three, for large - two. You could use whatever makes you comfortable, using higher power rating, the criteria being
1. Size. If it is big and fits, then
2. Cost. if it is not prohibitive, then
Use it.
Threads: 154
City: Westland, MI
You might want to think about painting a coat of corona dope on it. Works to insulate noisy flybacks, should work on the BC resistor. Take care, Gary
Threads: 563
How does corona cope stand to heat?
Threads: 64
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
