Threads: 271
City: Wilsonville
State, Province, Country: OR
Joe, thanks for the thoughts. Some of the rust was just surface rust but where my mouse friends had consistently made their deposits it was pretty well pitted. I used isopropanol to get the first layer of dirt and crud off followed by some GoJo and then some light wire brushing with a dremel tool to take off most of the surface stuff. The deeply corroded areas got multiple naval jelly treatments and eventually a heavier duty wire brushing. I put rustoleum primer on the pitted areas and sanded them down to get them smooth. For the rest of the areas I was trying to use a technique I think Phlogiston recommended of using a grayish paint with some green added to make a "wash" that goes over the areas where the cadmium coating was taken off. Unfortunately I didn't too too well at it and it looked like crap so I kept going with some rustoleum aluminum. (The fault was my skills, not Russ's approach!!) I did get the wash technique to work pretty well on the dial mounting bracket but I don't happen to have a pic of that yet. I'm sure I'll get another chance to practice it! There's always another rusty chassis!
[Image: https://www.dropbox.com/s/d7zdq5g3wd6s2g....jpg?raw=1]
[Image: https://www.dropbox.com/s/u0l6joygir9587....jpg?raw=1]
Threads: 563
I say it looks great.
Best is the enemy of good'nuff!
Threads: 271
City: Wilsonville
Threads: 310
City: Kings Park NY
one day I will be able to dismantle a chassis and then put it back together... correctly! ![Icon_lol Icon_lol](https://philcoradio.com/phorum/images/smilies/icon_lol.gif)
I'm at the good'nuff stage myself..
very nice
AC: 4 DC: 1
Threads: 271
City: Wilsonville
This isn't quite "electronic" restoration but it does deal with the chassis so...
I took a shot at reproducing the model # stamp that was on the back of the chassis...here's the original:
[Image: https://www.dropbox.com/s/910xiblvmbzvso....jpg?raw=1]
and here's the repro...
[Image: https://www.dropbox.com/s/5jq87meyo44jnc....jpg?raw=1]
I used a transfer technique (there are quite a few once you start looking for them) that uses freezer paper, inkjet printer and Microsoft word. I recreated the box and fonts in Word, then flipped the image so it would transfer correctly onto the chassis. I used a technique similar to that used in this blog: http://home-frosting.blogspot.com/2011/0...paper.html except I cut the freezer paper into a size just a bit larger then the image and taped it to a regular piece of paper (keeping the waxy side exposed. I then printed the image onto the waxy freezer paper, carefully cut out the image and pressed it onto the chassis. Its important to burnish the back of the paper with a spoon or hard round object to be sure to transfer as much of the ink as possible. I should have pressed mine a little harder. For a first try, I'm pleased. I'll coat it with a matte clear coat to keep it from rubbing off.
Threads: 55
City: Evanston, IL
Was reading this thread about the ink-stamp transfer on model number.
Great idea.
Also saw you had asked earlier about the "2 2" or "22" black stamped on the rear apron.
I'm thinking it would be the assy line number or inspector's number.
Maybe some internal dating code? Second week of second month or similar?
Chuck
Threads: 271
City: Wilsonville
Thanks Chuck. I suspect that if you and Ron aren't sure about the 2-2, no one will know.
Threads: 10
City: Glendale, CA
Bob,
That stamp transfer looks really nice, just like the factory.
Tom
Threads: 271
City: Wilsonville
OK..back to working on the chassis. Am doing the usual paper cap stuffing and rubber wire replacement. Stuffed the one electrolytic can that was still with the radio. Pretty straight forward, lots of room.
[Image: https://www.dropbox.com/s/hd7rvvpa8mf1uw....jpg?raw=1][Image: https://www.dropbox.com/s/nrfzxu13go1w1n....jpg?raw=1]
I've made dogbone resistors from molds as well as from bic pens with the wire wrapped around the end but I'd never made the resistors that were in this radio. Found some tubing at the harware store, cut it to the right length, slid in the new resistor, filled the ends with a little hot glue and finally painted them. To get the stripe on I put one lead in my electric screwdriver and rotated it while touching the paint brush to it. Takes a little practice but they come out nice. The first photo shows the process for a 70 ohm and the second shows the repro 70k ohm above the original.
[Image: https://www.dropbox.com/s/mra6j4lygiv4e9....jpg?raw=1][Image: https://www.dropbox.com/s/e0q8rhm6e6rt40....jpg?raw=1]
Threads: 271
City: Wilsonville
A technical question for you guys. A previous repair has replaced the #42 280 ohm wire wound resistor (Part No. 33-128431) with a 10 watt 250 ohm resistor. They also replaced the # 43 70 ohm 1/2 watt resistor with what looks like another 10 watt replacement. Probably OK but it sure is ugly. I'm replacing the 70 ohm with a correct reproduction. Any suggestions on what to do with replacing the 280 ohm? I have a much smaller 5 watt 300 ohm part that would be easier to hide but I'm not sure of what wattage I can actually use. Anyone have specs on the original part or an assessment of the wattage required? Thanks!!
[Image: https://www.dropbox.com/s/e7anw9z01323sf....jpg?raw=1]
[Image: https://www.dropbox.com/s/g5tw19ucly5z5y....jpg?raw=1]
Threads: 563
OK,
so the current through your 280 plus 70 is roughly the same as the current through the field coil.
Take the sch document, deduct B+ (SG of 41) fom the table from the 84's K voltage, and divide it by 2000, this is you current.
Use I-square times R to detemine your 280 and 70 dissipation, use comfort factor of two or more to determine ratings.
Threads: 271
City: Wilsonville
Thank you Mike!!
So that would be:
(((310-210)/2000)^2)*280 *2 = 1.4 watts
and similarly 0.35 watts for the 70 ohm resistor.
So the 0.5 watt spec for the 70 makes sense.
[Image: https://www.dropbox.com/s/tey162um7tw6ox....jpg?raw=1]
Threads: 563
I would go with at least 1W for 70 Ohm to keep it > 2 ratio.
Threads: 271
City: Wilsonville
Thanks! Actually those numbers include the 2x safety factor already.
Threads: 271
City: Wilsonville
OK this puppy is alive again. Replaced those ugly wirewound resistors, one with a reproduction 70 ohm 1/2 watt and the other with a 300 ohm 5 watt. Its a lot less visible than the older replacement and I should be able to get a 2 watt replacement that I can make look more original. Still have one electrolytic tacked in under the chassis since I haven't located the right can to stuff it topside...will keeplooking.
Here's the new look for the resistor replacements:
[Image: https://www.dropbox.com/s/cscnryhz7tgpzs....jpg?raw=1]
And the before and after on the entire underside with replaced rubber wire, recap and resistors restored.
[Image: https://www.dropbox.com/s/vqfyha59ifgtbl....jpg?raw=1][Image: https://www.dropbox.com/s/kla09goiqxb46t....jpg?raw=1]
Taking that pushbutton assembly out and putting it back isn't fun. Does anyone know if the little rubber pieces in the assembly are critical or not...doesn't seem so as its playing without them:
[Image: https://www.dropbox.com/s/iezjbwnnmsuo8i....jpg?raw=1]
Here's the topside still on the bench before alignment and dial plate replacement.
[Image: https://www.dropbox.com/s/jdw7m3mbd2ok1u....jpg?raw=1]
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
There are currently 2802 online users. [Complete List] » 2 Member(s) | 2800 Guest(s)
