  • 1 Vote(s) - 5 Average
Philco 20 Donated Finished
#31
Thanks. It is in the museum now.
Didn't think you had much more room in the museum!!
Outstanding restoration!
Icon_clapIcon_clapIcon_clap
#33
There is always one more spot, well, no there isn't, but I squeezed that one in. It was a donation. I have to keep it.
That's a beautiful restoration Russ, the shading looks perfect. Mark me down as another who would love to see a video of the making of your resistors.
