Recapping the recapped
Ever tried recapping 1960 recap? The fellow tried to fit all bypasses into the bakekite cases, for that he removed them all and cleaned only to find out the replacement capacitors would not fit.
[Image: http://i881.photobucket.com/albums/ac17/...51650a.jpg]
That's going to be fun Icon_crazy
Having it already , second day.
I just went through something simular on an philco 640. Only who ever did mine installed the bypass caps and left the old ones in the blocks in circuit.
I was about to start my 66 when I saw this update.
Exact same picture. Plus axial lytics.
This belongs in Philco Electronic Restoration, and has been moved there (here).
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1588 online users. [Complete List]
» 1 Member(s) | 1587 Guest(s)
