Shadow meter bulb?????
I am still working on my6 Philco 3650 and when I got it there was a bulb for the shadow meter in a small metal case and I don't see any way that it attaches behind the meter.. I would like to see a photo of the bulb in place.. Everything works But I don't know how the bulb stays in place.
Dan
http://www.antiqueradios.com/forums/view...5&t=241024
http://mcclellans.com/Philco16BCathedralRestoration.htm
http://www.tuberadioland.com/philco91d_main.html
http://www.ebay.com/itm/PHILCO-SHADOW-ME...3f39e57c12
(link is eBay but provided for clear picture's sake).
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1662 online users. [Complete List]
» 1 Member(s) | 1661 Guest(s)
