48-482 FM antenna
While waiting for my caps to arrive, I have been looking into the FM antenna situation on my radio. I have the "line cord antenna" which connects to pin 2 of the little plug on the chassis back. I have seen pictures of these radios with a very different FM antenna setup, a wire running in a single loop around the very back of the cabinet, but attached to the same pin 2. Having read Philco's instruction sheet for the radio, I see they say it should NOT be externally grounded. Looking at the schematic, I was thinking that using the present "line cord antenna" as a virtual ground, attached to pin 1 of the little plug, and a single loop antenna attached to pin 2 might give good results. Attached are the relevant schematics. Any thoughts ?
[Image: http://33.media.tumblr.com/fe95abf5dc211...1_1280.jpg]
[Image: http://37.media.tumblr.com/a6f46cbc42144...2_1280.jpg]
[Image: http://38.media.tumblr.com/422aee0f3f7b5...3_1280.jpg]
Leave the antenna connected to the line cord as is, it works very well. The location on the power cord is located 1/4 wavelength at FM broadcast freqs from the internal line to chassis caps which act as a ground to chassis. Therefore, 1/4 wavelength down the power cord, you are at a relative signal voltage maximum and this is where the capacitive coupling to the antenna input is located.
When operating correctly, the reception with the line antenna is excellent.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1531 online users. [Complete List]
» 1 Member(s) | 1530 Guest(s)
