  • 1 Vote(s) - 5 Average
Philco 38-7 CS restoration
#46
Icon_clapIcon_clapIcon_clap
Great job Bob!!!
#47
Nice job! another well done radio.
#48
Thanks guys! One last little task was to reproduce the missing chassis support board. This was made possible by another 38-7CS owner who kindly supplied a tracing and measurements.
I picked up a nice piece of 3/4" birch plywood and cut it out with a circular saw.
[Image: https://farm4.staticflickr.com/3917/1450...1dc2_c.jpg]
[Image: https://farm6.staticflickr.com/5570/1468...94ba_c.jpg]
Now the tricky bit - I need to drill holes for the rubber chassis mounts at just the right location. I put a drop of red paint on the chassis rods and carefully set the board in place. Now I know exactly where to drill Icon_smile
[Image: https://farm4.staticflickr.com/3894/1451...4ea6_c.jpg]
I used 1" and 1/2" forstner bits to create a stepped hole. It's a perfect fit.
[Image: https://farm3.staticflickr.com/2899/1450...d984_c.jpg]
It fits and the controls line up Icon_smile
[Image: https://farm4.staticflickr.com/3926/1470...0851_c.jpg]
[Image: https://farm4.staticflickr.com/3848/1451...8daf_c.jpg]
Finally I give it a few coats of Rustoluem camouflage brown paint.
[Image: https://farm3.staticflickr.com/2924/1463...a901_c.jpg]
#49
I've been following your videos on YouTube for this (and the electrical restoration). Excellent work Bob!! I was never a fan of chairsides but after seeing yours I want to go out and get one!
- Geoff
#50
I finally finished rubbing out the finish and assembled the radio Icon_smile
I used Behlen Deluxing compound for the final step.
[Image: https://farm6.staticflickr.com/5576/1519...2e6f_c.jpg]
[Image: https://farm4.staticflickr.com/3860/1521...9114_c.jpg]
The speaker mounted screws were painted with Rustoleum Dark Walnut gloss enamel. It's the closest I've found the the original color.
[Image: https://farm4.staticflickr.com/3930/1523...cf66_c.jpg]
Someday I'll get around to replacing the grille cloth.
[Image: https://farm4.staticflickr.com/3928/1539...0562_c.jpg]
Soaked the knobs in diluted, warm dishwashing liquid to remove years of crud.
[Image: https://farm4.staticflickr.com/3936/1542...acdc_c.jpg]
After a little tinkering, everything lines up well Icon_smile
[Image: https://farm3.staticflickr.com/2950/1541...3dd8_c.jpg]
#51
Here it is all back together next to my new sofa. I discovered the shelf is a nice spot to store a laptop.
[Image: https://farm3.staticflickr.com/2950/1527...c82e_c.jpg]
[Image: https://farm4.staticflickr.com/3948/1548...efe2_c.jpg]
Someday I hope to restore that Stromberg Carlson 231r next to it. Anyone have a spare glass top ?
[Image: https://farm3.staticflickr.com/2948/1548...1f88_c.jpg]
#52
Great job Bob, that's a real beauty Icon_thumbup
I like 38-7's dial. It looks especially good on a chairside.
#54
Great job!! Really like it. I dont have a chairside radio in my collection..........not yet.
There are currently 10186 online users. [Complete List]
» 2 Member(s) | 10184 Guest(s)
