08-17-2014, 08:49 AM
I think I would buy some cheap veneer and a piece 1/8 inch plywood and make a mock-up cabinet and do a couple of practice runs.
M R Radios C M Tubes
Second 70 Cabinet Finished
Steve M R Radios C M Tubes
08-17-2014, 11:11 AM
Steve,
Did you use biscuits when you joined the wood? Kirk Times I have been electrocuted in 2021
AC: 4 DC: 1
08-17-2014, 11:54 AM
Kirk, no biscuits. I just joint the edges and glue the together. The banding gives the core its strength. Or were you refering to using biscuits to join the veneer?
![]() Steve M R Radios C M Tubes
08-17-2014, 03:33 PM
[Image: https://farm5.staticflickr.com/4380/3720...575d_z.jpg]105_0861 by Steve Davis, on Flickr
Pattern attached to arch. [Image: https://farm5.staticflickr.com/4373/3697...2716_z.jpg]105_0863 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4390/3697...c1bf_z.jpg]105_0865 by Steve Davis, on Flickr Cutting the edge profile. [Image: https://farm5.staticflickr.com/4360/3652...6981_z.jpg]105_0866 by Steve Davis, on Flickr Finished top of the front arch. [Image: https://farm5.staticflickr.com/4395/3723...6939_z.jpg]105_0815 by Steve Davis, on Flickr Cutting the edge profile on the fluted columns. [Image: https://farm5.staticflickr.com/4357/3723...67a2_z.jpg]105_0823 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4348/3652...8ee6_z.jpg]105_0826 by Steve Davis, on Flickr Shaper setup to cut flutes in columns. [Image: https://farm5.staticflickr.com/4348/3652...8ee6_z.jpg]105_0826 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4353/3656...b816_z.jpg]105_0825 by Steve Davis, on Flickr Cutting the flutes. [Image: https://farm5.staticflickr.com/4359/3737...f924_z.jpg]105_0830 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4426/3652...2e9d_z.jpg]105_0828 by Steve Davis, on Flickr Columns ready to be cut to length.
08-17-2014, 03:50 PM
[Image: https://farm5.staticflickr.com/4397/3697...2e36_z.jpg]105_0868 by Steve Davis, on Flickr
Column block pattern. [Image: https://farm5.staticflickr.com/4347/3723...ba63_z.jpg]105_0869 by Steve Davis, on Flickr The edge profile has been cut on column blocks. [Image: https://farm5.staticflickr.com/4341/3697...7258_z.jpg]105_0871 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4344/3737...26e8_z.jpg]105_0872 by Steve Davis, on Flickr Parting column blocks on the table saw. [Image: https://farm5.staticflickr.com/4415/3737...112a_z.jpg]105_0874 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4343/3737...0c03_z.jpg]105_0873 by Steve Davis, on Flickr Finished blocks. Steve M R Radios C M Tubes
08-17-2014, 04:21 PM
[Image: https://farm5.staticflickr.com/4385/3737...7c8d_z.jpg]105_0878 by Steve Davis, on Flickr
Well, I have about 25 hours in this project and it is starting to look like a Philco 70! M R Radios C M Tubes
08-17-2014, 04:36 PM
Where do you get the orphan chassis and hardwear like escutcheons for the complete sets you are making? Have you thought of buying these up to use in your cabinets?
Nice step by step Steve, thanks, an inspiration.
Jerry A friend in need is a pest! Bill Slee ca 1970.
08-17-2014, 04:46 PM
Todd, when I buy radios, I usually buy the worst of the worst! Also when I see escutcheons, knobs, speakers and such at a reasonable price, I buy them and put them in my "someday kit".
08-17-2014, 05:05 PM
Being a hoarder, if i could do what you do i would probably buy any chassis i could and have an entire fleet of 70's. Not to downgrade Mr. Olivers cabinets but I think your cabinets look even better because it seems that you have payed more attention to grain detail on the veneers. You could sometimes tell that the Oliver cabinets were reproduction by the front arch veneer which didnt flow from one splice to the other or instead of strait grain it would be figgured.
Again, great job.
08-18-2014, 07:56 PM
I'm going to go ahead and add the dark accent to the flutes. It is much easier to do it now rather than wait until the cabinet is finished.
[Image: https://farm5.staticflickr.com/4431/3720...e2cf_z.jpg]105_0879 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4433/3697...e0ab_z.jpg]105_0880 by Steve Davis, on Flickr I masked off the edges, sprayed two coats of clear to seal the wood, then sprayed the dark toner. [Image: https://farm5.staticflickr.com/4380/3697...0bf9_z.jpg]105_0884 by Steve Davis, on Flickr The toner has been sanded off the face of the columns. [Image: https://farm5.staticflickr.com/4357/3741...d59a_z.jpg]105_0886 by Steve Davis, on Flickr I have drilled the columns and arch for dowels. [Image: https://farm5.staticflickr.com/4395/3741...f508_z.jpg]105_0889 by Steve Davis, on Flickr The columns have been glued to the arch. [Image: https://farm5.staticflickr.com/4427/3656...e33c_z.jpg]105_0891 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4346/3656...87c3_z.jpg]105_0892 by Steve Davis, on Flickr This is the piece that goes across the bottom. I have cut a cope on the ends to match the edge profile of the columns. Steve M R Radios C M Tubes
08-19-2014, 01:45 PM
Man I wish I had the tools you use.
Then I'd love to know how to use them ![]() ![]() ![]() Times I have been electrocuted in 2021
AC: 4 DC: 1
08-19-2014, 04:55 PM
[Image: https://farm5.staticflickr.com/4469/3701...420a_z.jpg]105_0897 by Steve Davis, on Flickr
[Image: https://farm5.staticflickr.com/4391/3701...31f1_z.jpg]105_0898 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4497/3660...079a_z.jpg]105_0900 by Steve Davis, on Flickr Cutting the groove in the back of the arch for the wrap-around. [Image: https://farm5.staticflickr.com/4501/3656...16f2_z.jpg]105_0902 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4364/3656...eb35_z.jpg]105_0905 by Steve Davis, on Flickr Making a rabbit cut for the base moulding. [Image: https://farm5.staticflickr.com/4410/3741...3c9a_z.jpg]105_0914 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4512/3724...c2d7_z.jpg]105_0916 by Steve Davis, on Flickr Drilling and counter boring the base for the chassis mounting bolts. [Image: https://farm5.staticflickr.com/4370/3724...dca0_z.jpg]105_0917 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4468/3724...936e_z.jpg]105_0924 by Steve Davis, on Flickr Attaching the arch to the base. Steve M R Radios C M Tubes
I think Steve first has a need for a tool, and then he either buys one or makes one, and by then he knows how to use it.
It is like any project, if you have a clear idea of what to do, then you have some ideas as to what tools could get it done.
08-23-2014, 08:49 PM
Forming the wrap-around
[Image: https://farm5.staticflickr.com/4474/3724...42c4_z.jpg]105_0921 by Steve Davis, on Flickr I used 1/8 inch Luan to make the wrap-around. In order to bend the wrap, I first soak it for a full day. [Image: https://farm5.staticflickr.com/4478/3724...7b97_z.jpg]105_0927 by Steve Davis, on Flickr After soaking, I bent the wrap and placed it between the legs of a small work table to hold it in a "U" shape. [Image: https://farm5.staticflickr.com/4390/3741...586e_z.jpg]105_0928 by Steve Davis, on Flickr The wrap was left to dry for two days to form. [Image: https://farm5.staticflickr.com/4387/3741...cd2d_z.jpg]105_0929 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4351/3656...da26_z.jpg]105_0932 by Steve Davis, on Flickr [Image: https://farm5.staticflickr.com/4481/3656...7aa8_z.jpg]105_0933 by Steve Davis, on Flickr This is a fixture I made for clamping the veneer to the curved wrap. [Image: https://farm5.staticflickr.com/4472/3722...f577_z.jpg]105_0936 by Steve Davis, on Flickr The wrap being installed. M R Radios C M Tubes
« Next Oldest | Next Newest »
Users browsing this thread: 20 Guest(s) |
