Philco 53C to strip or not to strip?
I say there is nothing to complain about.
Nice job Kirk.
It looks a lot better.
Looks excellent!!! Sooooo much better than before.
Hats off again! Looking forward to hanging out with yous guys in a couple of weeks!!!
+1 Terry!
It is like christmas for me and I've already sold half the radios I am bringing, Icon_lol
No Philco's though Icon_mrgreen
Kirk
No stip job! Best to leave it alone,it looks good the way it is. You know its a antique.
Agree, some character and signs of use are a benefit to many antiques including your nicely restored set. When it's just too gross for words, that's the time to strip and repair.
There are currently 8749 online users. [Complete List]
» 3 Member(s) | 8746 Guest(s)
