Radio Lamp
I attended an Estate sale, and bought this Radio lamp for $40.00 .
I replaced the cord , but used the original switch. I have always wanted a radio lamp, now I have one.. I have seen them on Ebay but they were too expensive..
Most unusual, neat.
Nice Find!Good Price!
   I found out that this radio lamps statue is   Marlene Dietrich
   Living in Calgary Alberta
LOL.  I thought you meant a radio by Radio Lamp Co., like this:
http://www.antiqueradios.com/forums/down...?id=108270
I love radio lamps, but they just don't come up often around here.  Nice find!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6932 online users. [Complete List]
» 1 Member(s) | 6931 Guest(s)
