A little Z restoration Chronicle DONE
Threads: 310
City: Kings Park NY
Hey Mike!
Radio works fine so no open filament i guess but when I plugged it into the tester it sparked inside and showed 0 on the meter. I actually did not test the radio after that. maybe it did blow now?
I'll get a new tube and see what happens.
I just thought that tube moght control the dial lamps
Kirk
AC: 4 DC: 1
Threads: 562
Kirk
If you read your post, (remember, English is my second language), your times are so confused I cannot make heads or tails of whether your radio works despite blown tube, or it does not....
Try to stick to the chronological order....
Threads: 337
City: lawrenceville nj
Threads: 310
City: Kings Park NY
well, she is dead now so I guess that 14C7 is blown. Funny, it did not blow until I tried to test it.
hopefully when I get the new tube it will fix the problem.
Thanks for the help
Kirk
AC: 4 DC: 1
Threads: 562
Bad switches / bad setting on the tester?
Or, switching while the tube is in and the voltages are applied?
Threads: 310
City: Kings Park NY
Well, A buddy made me a decal and it is perfect except for the color. He does not have the gold in the middle but it is the perfect size.
Better than $16.00 for 4 at radiodaze.
I think I can live with it but i'm not sure....
what do you guys think?
Image(s)
AC: 4 DC: 1
Threads: 562
This is the wrong forum to ask this.
You know how people here are: the uglier a Z is, the better
So whatever the answer is, you have to take it with a grain of salt.
Threads: 55
City: Lexington, KY
He did a nice job but the lack of gold would bother me. I guess white and gold are two colors we can't duplicate very easily with homemade decals.
Threads: 562
OK, Kirk, don't let John in. Or when he comes, turn the Z away.
City: Sedona, AZ/Placentia/CA
I agree with John, even though it is a Z it does deserve proper coloring on the decal. Excellent job on the graphics but inkjet printers other than black are too transparent when used on decals. They pick up the wood color and of course as John indicated, no gold or white.
Kirk, spend the $16 for a set of 4 and sell the extras off for $8 apiece to others in need! You could make a little money.
Best, Jerry
Threads: 310
City: Kings Park NY
I knew that would be your answer guys
I guess it's back to radio daze...
Now I have to try and remove it
AC: 4 DC: 1
Threads: 562
Next time post them before pasting. This will save you the trouble of removing.
Mike, your cruel!
Ya never know what they will look like (home made decals) until applied when you see the true colors. I have tried many times. I love to read the bantering back and forth between you and Kirk. Don't pick on Kirk (I know your friends) I enjoy reading the stuff but your spelling is absolutely terrible. Kirk is better. My spelling is only slightly better but credit to both of you. My Spanish is bad and my French is even worth.
Enjoy your dialog back and forth.
Best, Jerry
Threads: 562
My spelling is great! But the touch keyboard on my iPad creates lots of typos. You think you pressed a key and what you pressed is the one next to it.
Threads: 310
City: Kings Park NY
Case in point: your French is even worth
Friends? I don't even like him
I give him hot chassis hoping he will get shocked real good
I even solder the b+ to the ground sometimes
Kirk
AC: 4 DC: 1
(This post was last modified: 09-05-2014, 05:16 PM by
OldRestorer .)
What is "everything else?"
Try to be more specific in your descriptions:...morzh — 12:44 PM
Yeah, I'm still on 5TPO. Sorry, my bad, points 1 and 2 should be points 18 and 19 (easy mistake :think: ) X7 is shown ...R3Sons — 11:42 AM
Quick progress report:
I've replaced...R3Sons — 05:05 PM
All need to go and be replaced.morzh — 04:36 PM
There are currently 4672 online users. [Complete List ]» 2 Member(s) | 4670 Guest(s)
