Philco model 10 speaker
Did the model 10 speaker come with more than one type of plug . The one I have has the large plug as is used in the 87 and the 65. The picture in the gallery shows a model 10 next to a model 77 but the receptical on the 77 takes a smaller plug.
Model 10??? That should be Model F-10.
Models 65, 76 and 95 table models use the large speaker plug; Models 77 and 96 table models would use the small speaker plug. The two variations of the table model speaker are otherwise identical.
Oh, and the table model is also pictured in the June 1929 and Fall 1929 Gallery pages.
Thanks for the info Ron.
Eico 232 VTVM Schematic
There are currently 6695 online users. [Complete List]
» 3 Member(s) | 6692 Guest(s)
